It will be updated again, and you forced to change it every time when your ISP changes an IP.
I would suggest to register an DDNS domain and use it instead of IP in your docker run command: Port Forwarding - Node Operator
my storj still offline my ip port is open also
i am using node dashboard
Hello @Vishal ,
If your port is open on Open Port Check Tool - Test Port Forwarding on Your Router then please, check your identity: Identity - Node Operator
dear sir
port also open and i checked the identity also but no response
