Yes! I did a reboot and tried to refresh my dashboard.
But I have another problem : after refreshing my node, I can’t boot … I have the following message : “You are in emergency mode …”. For security reason, I disabled the root account.
I just tried to mount my HD with my Rpi OS and it seems that I can mount the HD on my other computer. I don’t understand what’s happened…
Also how did you disable the root account because sometimes if you make a mod to certin config files and the modification was wrong rebooting can cause issues
Ok have you tried pulling the cable and trying again after plugging it back in
Also would you happen to have a swap file on the USB that can make this happen if the USB isn’t in the pi
Regarding ufw configuration, the only things I tried, in second action, to disable ufw to see if it wasn’t a problem of firewall. But my node was still offline…
Hmm I see the next step is check routers port forwarding maybe your IP changed or something and know the forwarding is wrong ? I don’t know but also worth a look
Yes I tried to pull the cable and plug it back but same things.
I also tried to access to the HD with another computer but no problem.
I’m copying my node files and maybe I will make again a fresh installation.
Do you have any USB devices that are normally plugged in but aren’t now ?
Also if you try to remove everything except the keyboard and HDD if it’s USB HDD it may boot
Is the HDD plugged in if not it may not boot for that reason
I just tried to plug only my HDD with my Rpi OS. Before to have a message “You are in emergency mode …”, just after the “mounted /boot”, I have a long time message : “A start job is running for dev.…”.
