Satellite suspension
Hello Sirs,
2 satellites have very low values. Node have been offline couple of days, but why it is 9 and 4%?
Logs are fine:
What to do?
Regards,
Alexander
Hello @Aka985,
Welcome back!
It’s a known issue with some nodes, see
and
Perhaps this should help with EU1:
You need to use these scripts to see did it help or not:
If it’s helped, you shouldn’t have any recent days with missing audits in the report.
Stop using your dynamic DNS service.
Apparently you’ve neglected to notice this problem for several weeks.
Hardcode or script your IP into the config.yaml, or change Dyn DNS provider - STAT.
2 cents,
Julio
Oh, yes, it could be related to a crappy DuckDNS or ASUS DDNS providers.
If you use one of them, please migrate to NoIP or Cloudflare.
