Storjstats.info offline?
Am I the only one who is seeing „Grafana has failed to load it’s application files“?
Best wishes
I just checked and it looks offline to me too. I’m sure it will be back shortly.
If you really needs some info: assume node count went up a bit, available-space went up a bit, and used-space didn’t change :wink:
It’s Not that important.
I love stats and sometimes I Look there and yesterday I saw it’s broken :wink:
It’s loading for me now at the time of this post
Can confirm, it’s working again :+1:
Looks like its back up! Wasn’t working for me yesterday.
@bre looks like it’s offline again :wink:
It’s a Community resource, we can do nothing about it, sorry!
See
Sheesh, seems i definitley need to improve my monitoring ^^
At least the communitydriven Websitechecker is working very well :stuck_out_tongue:
Its UP&Running again, Data should be provided soon, thanks for notification!
What @Alexey said
20 characters
And by the way @Arkina, although your update has garnered some likes, I don’t think this topic is ‘solved’ until someone just says ‘thanks’ for your continued support/efforts.
So thanks, again… n’ stuff. You’re appreciated. :smiley:
2 cents,
Julio
@Arkina storjstats.info seems to be offline again.
Thank you for your Dashboard.
Update: Working again.
