Corrupt node after power outage
Hi :slight_smile:
had a really bad power outage and 2 nodes have a corrupt filesystem but are running at least “normal”. One stopped working completly after a clean reboot. The filesystem seems fine but the dbs where broken. I moved them all to another folder and recreated them. With the new files I still get this error and my needs reboots after seconds. What should I else do?
  INFO    Got a signal from the OS: "terminated"  {"Process": "storagenode-updater"}
2024-09-02 20:26:33,335 INFO stopped: storagenode-updater (exit status 0)
2024-09-02T20:26:33+02:00       ERROR   failure during run      {"Process": "storagenode", "error": "Error during preflight check for storagenode databases: preflight: database: \"piece_expiration\": failed inserting test value: context canceled\n\tstorj.io/storj/storagenode/storagenodedb.(*DB).preflight:513\n\tstorj.io/storj/storagenode/storagenodedb.(*DB).Preflight:438\n\tmain.cmdRun:115\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.cleanup.func1.4:392\n\tstorj.io/common/process.cleanup.func1:410\n\tgithub.com/spf13/cobra.(*Command).execute:983\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1115\n\tgithub.com/spf13/cobra.(*Command).Execute:1039\n\tstorj.io/common/process.ExecWithCustomOptions:112\n\tmain.main:34\n\truntime.main:271", "errorVerbose": "Error during preflight check for storagenode databases: preflight: database: \"piece_expiration\": failed inserting test value: context canceled\n\tstorj.io/storj/storagenode/storagenodedb.(*DB).preflight:513\n\tstorj.io/storj/storagenode/storagenodedb.(*DB).Preflight:438\n\tmain.cmdRun:115\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.cleanup.func1.4:392\n\tstorj.io/common/process.cleanup.func1:410\n\tgithub.com/spf13/cobra.(*Command).execute:983\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1115\n\tgithub.com/spf13/cobra.(*Command).Execute:1039\n\tstorj.io/common/process.ExecWithCustomOptions:112\n\tmain.main:34\n\truntime.main:271\n\tmain.cmdRun:117\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.cleanup.func1.4:392\n\tstorj.io/common/process.cleanup.func1:410\n\tgithub.com/spf13/cobra.(*Command).execute:983\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1115\n\tgithub.com/spf13/cobra.(*Command).Execute:1039\n\tstorj.io/common/process.ExecWithCustomOptions:112\n\tmain.main:34\n\truntime.main:271"}
Error: Error during preflight check for storagenode databases: preflight: database: "piece_expiration": failed inserting test value: context canceled
        main.cmdRun:115
        main.main:34
        runtime.main:271
2024-09-02 20:26:33,688 INFO stopped: storagenode (exit status 1)
2024-09-02 20:26:33,697 INFO stopped: processes-exit-eventlistener (terminated by SIGTERM)
You need to fix the filesystem (you likely need to run the fsck command several times until it wouldn’t throw any warnings and errors), then you need to check and fix the databases:
or re-create the corrupted ones (losing the history and stat):
The drive is not the one with the filesystem errors. Sorry if that was no clear :smiley:
I did exactly that guide to recreate them but without moving the old ones back. Stat is not important for me.
piece_expiration.db: re-name it - leave it renamed, try delete all others, replacement upon re-start again. Context cancelled seems to me = it gave up, be it time-out, hard fault what have you. Possible bad cluster, scan entire disk thereafter, ie: used AND free space.
1/3 cent
Sounds like starting from scratch is easier?
Just move all *.db files to backup dir. Then manually update your storagenode.exe to newest version - then start service.
Try that
If you believe so. But if the node is old enough, it could be useful to fix the issue instead.
If the node cannot open a database file, it could mean that the disk may have issues, you may try to move the databases to a different drive:
Yes the Node is really old, but brand new DBs are not working and moving them should change nothing.
Scanned the drive for filesystem errors und found nothing.
I dont know what to do :see_no_evil:
Please, search for Unrecoverable and/or FATAL errors in the logs, there is still a chance, that the root cause is not the inability to open a database, otherwise moving them could help actually. Because the “context canceled” usually meaning a timeout, so your disks cannot respond as quick as they should.
I created a folder on my SSD and let the docker create all DBs new to make sure they are clean. Same error still and I think I now know why…
The storage-dir-verification file was missing.
Glad I made a backup of that file. Now I am back online :smiley:
Now that all DBs are new, I wonder if the dashboard will update the real used memory again over time?
New error after some hours. Read it normal for a new database. Should I change something or just let it run?
2024-09-04T18:20:26+02:00       ERROR   blobscache      satPiecesContentSize < 0        {"Process": "storagenode", "satPiecesContentSize": -3328}
Yes, when the used-space-filewalker would finish the scan without errors.
So, not new, and the solution is the same - you need to have all used-space-filewalker finished without errors.
You may track them:
docker logs storagenode 2>&1 | grep "\sused-space" | grep -E "started|completed"
Thank you!
I dont get any results with the command:
docker logs storagenode_14TB_WD_Storj_2 2>&1 | grep "\sused-space" | grep -E "started|completed"
Does this mean its not running?
You may check do you have any errors related to a filewalker:
docker logs storagenode_14TB_WD_Storj_2 2>&1 | grep "error" | grep "filewalker"
The problem with a docker local logs driver, that it has only 5 files 20MiB each, so only 100MiB of logs, and likely it lost these lines already. You may increase the number of log files and/or their size, or redirect logs to the file to have a longer history. But in the latter case you also want to configure a logrotate to do not allow to grow it indefinitely:
The alternative method is to use an endpoint /mon/ps on the debug port, or use a simple naïve method of listing blobs folders by the access date (if you have enabled it) or this approach:
Restarted the node to trigger some errors:
2024-09-06T09:51:35+02:00       INFO    lazyfilewalker.used-space-filewalker    subprocess exited with status   {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "status": -1, "error": "signal: killed"}
2024-09-06T09:51:35+02:00       ERROR   pieces  used-space-filewalker failed    {"Process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Lazy File Walker": true, "error": "lazyfilewalker: signal: killed", "errorVerbose": "lazyfilewalker: signal: killed\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:85\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkAndComputeSpaceUsedBySatellite:133\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkAndComputeSpaceUsedBySatellite:722\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:81\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
2024-09-06T09:51:35+02:00       ERROR   pieces  used-space-filewalker failed    {"Process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Lazy File Walker": false, "error": "filewalker: context canceled", "errorVerbose": "filewalker: context canceled\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePieces:74\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatellite:79\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkAndComputeSpaceUsedBySatellite:731\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:81\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
2024-09-06T09:51:35+02:00       ERROR   piecestore:cache        encountered error while computing space used by satellite       {"Process": "storagenode", "error": "filewalker: context canceled", "errorVerbose": "filewalker: context canceled\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePieces:74\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatellite:79\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkAndComputeSpaceUsedBySatellite:731\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:81\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78", "SatelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-09-06T09:51:35+02:00       ERROR   lazyfilewalker.used-space-filewalker    failed to start subprocess      {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "error": "context canceled"}
2024-09-06T09:51:35+02:00       ERROR   pieces  used-space-filewalker failed    {"Process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Lazy File Walker": true, "error": "lazyfilewalker: context canceled", "errorVerbose": "lazyfilewalker: context canceled\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:73\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkAndComputeSpaceUsedBySatellite:133\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkAndComputeSpaceUsedBySatellite:722\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:81\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
2024-09-06T09:51:35+02:00       ERROR   pieces  used-space-filewalker failed    {"Process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Lazy File Walker": false, "error": "filewalker: context canceled", "errorVerbose": "filewalker: context canceled\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePieces:74\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatellite:79\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkAndComputeSpaceUsedBySatellite:731\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:81\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
2024-09-06T09:51:35+02:00       ERROR   piecestore:cache        encountered error while computing space used by satellite       {"Process": "storagenode", "error": "filewalker: context canceled", "errorVerbose": "filewalker: context canceled\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePieces:74\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatellite:79\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkAndComputeSpaceUsedBySatellite:731\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:81\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78", "SatelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-09-06T09:51:35+02:00       INFO    lazyfilewalker.trash-cleanup-filewalker subprocess exited with status   {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "status": -1, "error": "signal: killed"}
2024-09-06T09:51:35+02:00       ERROR   pieces:trash    emptying trash failed   {"Process": "storagenode", "error": "pieces error: lazyfilewalker: signal: killed", "errorVerbose": "pieces error: lazyfilewalker: signal: killed\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:85\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkCleanupTrash:195\n\tstorj.io/storj/storagenode/pieces.(*Store).EmptyTrash:436\n\tstorj.io/storj/storagenode/pieces.(*TrashChore).Run.func1.1:84\n\tstorj.io/common/sync2.(*Workplace).Start.func1:89"}
2024-09-06T09:51:35+02:00       INFO    lazyfilewalker.gc-filewalker    subprocess exited with status   {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "status": -1, "error": "signal: killed"}
2024-09-06T09:51:35+02:00       ERROR   pieces  lazyfilewalker failed   {"Process": "storagenode", "error": "lazyfilewalker: signal: killed", "errorVerbose": "lazyfilewalker: signal: killed\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:85\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkSatellitePiecesToTrash:163\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkSatellitePiecesToTrash:575\n\tstorj.io/storj/storagenode/retain.(*Service).retainPieces:380\n\tstorj.io/storj/storagenode/retain.(*Service).Run.func2:265\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
2024-09-06T09:51:35+02:00       ERROR   retain  retain pieces failed    {"Process": "storagenode", "cachePath": "config/retain", "error": "retain: filewalker: context canceled", "errorVerbose": "retain: filewalker: context canceled\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePieces:74\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePiecesToTrash:181\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkSatellitePiecesToTrash:582\n\tstorj.io/storj/storagenode/retain.(*Service).retainPieces:380\n\tstorj.io/storj/storagenode/retain.(*Service).Run.func2:265\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
You need to search for a previous error, which was invoked the node’s kill, all these messages are a consequence of the killing command somewhere earlier. Please search for Unrecoverable error in the logs.
I cant find any Unrecoverable errors after restart. This are all logs filewalker related. Is there something useful in it?
docker logs storagenode_14TB_WD_Storj_2 2>&1 | grep "filewalker"
2024-09-09T13:21:19+02:00       INFO    pieces  used-space-filewalker started   {"Process": "storagenode", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-09-09T13:21:19+02:00       INFO    lazyfilewalker.gc-filewalker    starting subprocess     {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-09-09T13:21:19+02:00       INFO    lazyfilewalker.gc-filewalker    subprocess started      {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-09-09T13:21:19+02:00       INFO    lazyfilewalker.trash-cleanup-filewalker starting subprocess     {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-09-09T13:21:19+02:00       INFO    lazyfilewalker.trash-cleanup-filewalker subprocess started      {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-09-09T13:21:19+02:00       INFO    lazyfilewalker.used-space-filewalker    starting subprocess     {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-09-09T13:21:19+02:00       INFO    lazyfilewalker.used-space-filewalker    subprocess started      {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-09-09T13:21:19+02:00       INFO    lazyfilewalker.trash-cleanup-filewalker.subprocess      trash-filewalker started        {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Process": "storagenode", "dateBefore": "2024-09-02T13:21:19+02:00"}
2024-09-09T13:21:20+02:00       INFO    lazyfilewalker.used-space-filewalker.subprocess Database started        {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Process": "storagenode"}
2024-09-09T13:21:20+02:00       INFO    lazyfilewalker.trash-cleanup-filewalker.subprocess      Database started        {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Process": "storagenode"}
2024-09-09T13:21:20+02:00       INFO    lazyfilewalker.gc-filewalker.subprocess Database started        {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Process": "storagenode"}
2024-09-09T13:21:20+02:00       INFO    lazyfilewalker.gc-filewalker.subprocess gc-filewalker started   {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "bloomFilterSize": 33586, "Process": "storagenode", "createdBefore": "2024-09-01T03:57:25+02:00"}
2024-09-09T13:21:20+02:00       INFO    lazyfilewalker.trash-cleanup-filewalker.subprocess      trash-filewalker completed      {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Process": "storagenode", "bytesDeleted": 0, "numKeysDeleted": 0}
2024-09-09T13:21:20+02:00       INFO    lazyfilewalker.trash-cleanup-filewalker subprocess finished successfully        {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-09-09T13:21:20+02:00       INFO    lazyfilewalker.trash-cleanup-filewalker starting subprocess     {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-09-09T13:21:20+02:00       INFO    lazyfilewalker.trash-cleanup-filewalker subprocess started      {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-09-09T13:21:20+02:00       INFO    lazyfilewalker.trash-cleanup-filewalker.subprocess      trash-filewalker started        {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "dateBefore": "2024-09-02T13:21:20+02:00", "Process": "storagenode"}
2024-09-09T13:21:20+02:00       INFO    lazyfilewalker.trash-cleanup-filewalker.subprocess      Database started        {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Process": "storagenode"}
2024-09-09T13:23:20+02:00       INFO    lazyfilewalker.gc-filewalker    subprocess exited with status   {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "status": -1, "error": "signal: killed"}
2024-09-09T13:23:20+02:00       ERROR   pieces  lazyfilewalker failed   {"Process": "storagenode", "error": "lazyfilewalker: signal: killed", "errorVerbose": "lazyfilewalker: signal: killed\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:85\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkSatellitePiecesToTrash:163\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkSatellitePiecesToTrash:575\n\tstorj.io/storj/storagenode/retain.(*Service).retainPieces:380\n\tstorj.io/storj/storagenode/retain.(*Service).Run.func2:265\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
2024-09-09T13:23:20+02:00       ERROR   filewalker      failed to get progress from database    {"Process": "storagenode"}
2024-09-09T13:23:20+02:00       INFO    lazyfilewalker.trash-cleanup-filewalker subprocess exited with status   {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "status": -1, "error": "signal: killed"}
2024-09-09T13:23:20+02:00       ERROR   pieces:trash    emptying trash failed   {"Process": "storagenode", "error": "pieces error: lazyfilewalker: signal: killed", "errorVerbose": "pieces error: lazyfilewalker: signal: killed\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:85\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkCleanupTrash:195\n\tstorj.io/storj/storagenode/pieces.(*Store).EmptyTrash:436\n\tstorj.io/storj/storagenode/pieces.(*TrashChore).Run.func1.1:84\n\tstorj.io/common/sync2.(*Workplace).Start.func1:89"}
2024-09-09T13:23:20+02:00       INFO    lazyfilewalker.used-space-filewalker    subprocess exited with status   {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "status": -1, "error": "signal: killed"}
2024-09-09T13:23:20+02:00       ERROR   pieces  used-space-filewalker failed    {"Process": "storagenode", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Lazy File Walker": true, "error": "lazyfilewalker: signal: killed", "errorVerbose": "lazyfilewalker: signal: killed\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:85\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkAndComputeSpaceUsedBySatellite:133\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkAndComputeSpaceUsedBySatellite:722\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:81\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
2024-09-09T13:23:20+02:00       ERROR   retain  retain pieces failed    {"Process": "storagenode", "cachePath": "config/retain", "error": "retain: filewalker: context canceled", "errorVerbose": "retain: filewalker: context canceled\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePieces:74\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePiecesToTrash:181\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkSatellitePiecesToTrash:582\n\tstorj.io/storj/storagenode/retain.(*Service).retainPieces:380\n\tstorj.io/storj/storagenode/retain.(*Service).Run.func2:265\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
2024-09-09T13:23:20+02:00       ERROR   pieces  used-space-filewalker failed    {"Process": "storagenode", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Lazy File Walker": false, "error": "filewalker: context canceled", "errorVerbose": "filewalker: context canceled\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePieces:74\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatellite:79\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkAndComputeSpaceUsedBySatellite:731\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:81\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
2024-09-09T13:23:20+02:00       ERROR   piecestore:cache        encountered error while computing space used by satellite       {"Process": "storagenode", "error": "filewalker: context canceled", "errorVerbose": "filewalker: context canceled\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePieces:74\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatellite:79\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkAndComputeSpaceUsedBySatellite:731\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:81\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78", "SatelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-09-09T13:23:20+02:00       INFO    pieces  used-space-filewalker started   {"Process": "storagenode", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-09-09T13:23:20+02:00       INFO    lazyfilewalker.used-space-filewalker    starting subprocess     {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-09-09T13:23:20+02:00       ERROR   lazyfilewalker.used-space-filewalker    failed to start subprocess      {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "error": "context canceled"}
2024-09-09T13:23:20+02:00       ERROR   pieces  used-space-filewalker failed    {"Process": "storagenode", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Lazy File Walker": true, "error": "lazyfilewalker: context canceled", "errorVerbose": "lazyfilewalker: context canceled\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:73\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkAndComputeSpaceUsedBySatellite:133\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkAndComputeSpaceUsedBySatellite:722\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:81\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
2024-09-09T13:23:20+02:00       ERROR   pieces  used-space-filewalker failed    {"Process": "storagenode", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Lazy File Walker": false, "error": "filewalker: context canceled", "errorVerbose": "filewalker: context canceled\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePieces:74\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatellite:79\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkAndComputeSpaceUsedBySatellite:731\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:81\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
2024-09-09T13:23:20+02:00       ERROR   piecestore:cache        encountered error while computing space used by satellite       {"Process": "storagenode", "error": "filewalker: context canceled", "errorVerbose": "filewalker: context canceled\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePieces:74\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatellite:79\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkAndComputeSpaceUsedBySatellite:731\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:81\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78", "SatelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-09-09T13:23:20+02:00       INFO    pieces  used-space-filewalker started   {"Process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-09-09T13:23:20+02:00       INFO    lazyfilewalker.used-space-filewalker    starting subprocess     {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-09-09T13:23:20+02:00       ERROR   lazyfilewalker.used-space-filewalker    failed to start subprocess      {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "error": "context canceled"}
2024-09-09T13:23:20+02:00       ERROR   pieces  used-space-filewalker failed    {"Process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Lazy File Walker": true, "error": "lazyfilewalker: context canceled", "errorVerbose": "lazyfilewalker: context canceled\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:73\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkAndComputeSpaceUsedBySatellite:133\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkAndComputeSpaceUsedBySatellite:722\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:81\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
2024-09-09T13:23:20+02:00       ERROR   pieces  used-space-filewalker failed    {"Process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Lazy File Walker": false, "error": "filewalker: context canceled", "errorVerbose": "filewalker: context canceled\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePieces:74\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatellite:79\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkAndComputeSpaceUsedBySatellite:731\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:81\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
2024-09-09T13:23:20+02:00       ERROR   piecestore:cache        encountered error while computing space used by satellite       {"Process": "storagenode", "error": "filewalker: context canceled", "errorVerbose": "filewalker: context canceled\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePieces:74\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatellite:79\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkAndComputeSpaceUsedBySatellite:731\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:81\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78", "SatelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-09-09T13:23:20+02:00       INFO    pieces  used-space-filewalker started   {"Process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-09-09T13:23:20+02:00       INFO    lazyfilewalker.used-space-filewalker    starting subprocess     {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-09-09T13:23:20+02:00       ERROR   lazyfilewalker.used-space-filewalker    failed to start subprocess      {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "error": "context canceled"}
2024-09-09T13:23:20+02:00       ERROR   pieces  used-space-filewalker failed    {"Process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Lazy File Walker": true, "error": "lazyfilewalker: context canceled", "errorVerbose": "lazyfilewalker: context canceled\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:73\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkAndComputeSpaceUsedBySatellite:133\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkAndComputeSpaceUsedBySatellite:722\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:81\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
2024-09-09T13:23:20+02:00       ERROR   pieces  used-space-filewalker failed    {"Process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Lazy File Walker": false, "error": "filewalker: context canceled", "errorVerbose": "filewalker: context canceled\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePieces:74\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatellite:79\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkAndComputeSpaceUsedBySatellite:731\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:81\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
2024-09-09T13:23:20+02:00       ERROR   piecestore:cache        encountered error while computing space used by satellite       {"Process": "storagenode", "error": "filewalker: context canceled", "errorVerbose": "filewalker: context canceled\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePieces:74\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatellite:79\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkAndComputeSpaceUsedBySatellite:731\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:81\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78", "SatelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-09-09T13:23:37+02:00       INFO    lazyfilewalker.trash-cleanup-filewalker starting subprocess     {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-09-09T13:23:37+02:00       INFO    lazyfilewalker.trash-cleanup-filewalker subprocess started      {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-09-09T13:23:37+02:00       INFO    pieces  used-space-filewalker started   {"Process": "storagenode", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-09-09T13:23:37+02:00       INFO    lazyfilewalker.used-space-filewalker    starting subprocess     {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-09-09T13:23:37+02:00       INFO    lazyfilewalker.gc-filewalker    starting subprocess     {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-09-09T13:23:37+02:00       INFO    lazyfilewalker.used-space-filewalker    subprocess started      {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-09-09T13:23:37+02:00       INFO    lazyfilewalker.gc-filewalker    subprocess started      {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-09-09T13:23:37+02:00       INFO    lazyfilewalker.trash-cleanup-filewalker.subprocess      trash-filewalker started        {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Process": "storagenode", "dateBefore": "2024-09-02T13:23:37+02:00"}
2024-09-09T13:23:37+02:00       INFO    lazyfilewalker.trash-cleanup-filewalker.subprocess      Database started        {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Process": "storagenode"}
2024-09-09T13:23:37+02:00       INFO    lazyfilewalker.used-space-filewalker.subprocess Database started        {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Process": "storagenode"}
2024-09-09T13:23:37+02:00       INFO    lazyfilewalker.gc-filewalker.subprocess Database started        {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Process": "storagenode"}
2024-09-09T13:23:37+02:00       INFO    lazyfilewalker.gc-filewalker.subprocess gc-filewalker started   {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "bloomFilterSize": 33586, "Process": "storagenode", "createdBefore": "2024-09-01T03:57:25+02:00"}
2024-09-09T13:23:37+02:00       INFO    lazyfilewalker.trash-cleanup-filewalker.subprocess      trash-filewalker completed      {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Process": "storagenode", "bytesDeleted": 0, "numKeysDeleted": 0}
2024-09-09T13:23:37+02:00       INFO    lazyfilewalker.trash-cleanup-filewalker subprocess finished successfully        {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-09-09T13:23:37+02:00       INFO    lazyfilewalker.trash-cleanup-filewalker starting subprocess     {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-09-09T13:23:37+02:00       INFO    lazyfilewalker.trash-cleanup-filewalker subprocess started      {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-09-09T13:23:37+02:00       INFO    lazyfilewalker.trash-cleanup-filewalker.subprocess      trash-filewalker started        {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Process": "storagenode", "dateBefore": "2024-09-02T13:23:37+02:00"}
2024-09-09T13:23:37+02:00       INFO    lazyfilewalker.trash-cleanup-filewalker.subprocess      Database started        {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Process": "storagenode"}
Maybe it’s happened after the restart, because the container first downloads a current latest version of storagenode and storagenode-updater, then start them, and if storagenode-updater noticed a new version, it killed storagenode and updated it.
You can see that in the unfiltered logs, however, if you redirected logs to the file, then the events from storagenode-updater would remain in docker logs, while the node’s logs will be in the log file and absent in docker logs for that node.
At least now it looks exactly like an external kill signal, then the new instance of storagenode has been re-spawned.
I changed to the log file option and it looks like Filewalker starts and finishs every few hours.
Is this normal behavior?
Unfortunately, the used space in the GUI is still very far from reality. There are about 10TB occupied, but so far only 0.77TB used and 2.79TB in trash are displayed. So there is still a lot missing.
Do I have to do something or just wait and see? The process seems to be running.
Here are the Filewalker logs since the last restart:
~/Downloads/node (4).log:18: 2024-09-12T10:30:02+02:00	INFO	lazyfilewalker.trash-cleanup-filewalker	starting subprocess	{"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
~/Downloads/node (4).log:24: 2024-09-12T10:30:02+02:00	INFO	pieces	used-space-filewalker started	{"Process": "storagenode", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
~/Downloads/node (4).log:25: 2024-09-12T10:30:02+02:00	INFO	lazyfilewalker.used-space-filewalker	starting subprocess	{"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
~/Downloads/node (4).log:28: 2024-09-12T10:30:02+02:00	INFO	lazyfilewalker.trash-cleanup-filewalker	subprocess started	{"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
~/Downloads/node (4).log:29: 2024-09-12T10:30:02+02:00	INFO	lazyfilewalker.used-space-filewalker	subprocess started	{"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
~/Downloads/node (4).log:36: 2024-09-12T10:30:02+02:00	INFO	lazyfilewalker.trash-cleanup-filewalker.subprocess	trash-filewalker started	{"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Process": "storagenode", "dateBefore": "2024-09-05T10:30:02+02:00"}
~/Downloads/node (4).log:37: 2024-09-12T10:30:02+02:00	INFO	lazyfilewalker.trash-cleanup-filewalker.subprocess	Database started	{"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Process": "storagenode"}
~/Downloads/node (4).log:38: 2024-09-12T10:30:02+02:00	INFO	lazyfilewalker.used-space-filewalker.subprocess	Database started	{"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Process": "storagenode"}
~/Downloads/node (4).log:39: 2024-09-12T10:30:03+02:00	INFO	lazyfilewalker.trash-cleanup-filewalker.subprocess	trash-filewalker completed	{"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Process": "storagenode", "bytesDeleted": 0, "numKeysDeleted": 0}
~/Downloads/node (4).log:40: 2024-09-12T10:30:03+02:00	INFO	lazyfilewalker.trash-cleanup-filewalker	subprocess finished successfully	{"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
~/Downloads/node (4).log:43: 2024-09-12T10:30:03+02:00	INFO	lazyfilewalker.trash-cleanup-filewalker	starting subprocess	{"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
~/Downloads/node (4).log:44: 2024-09-12T10:30:03+02:00	INFO	lazyfilewalker.trash-cleanup-filewalker	subprocess started	{"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
~/Downloads/node (4).log:45: 2024-09-12T10:30:03+02:00	INFO	lazyfilewalker.trash-cleanup-filewalker.subprocess	trash-filewalker started	{"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Process": "storagenode", "dateBefore": "2024-09-05T10:30:03+02:00"}
~/Downloads/node (4).log:46: 2024-09-12T10:30:03+02:00	INFO	lazyfilewalker.trash-cleanup-filewalker.subprocess	Database started	{"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Process": "storagenode"}
~/Downloads/node (4).log:17484: 2024-09-12T11:57:35+02:00	INFO	lazyfilewalker.used-space-filewalker	subprocess finished successfully	{"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
~/Downloads/node (4).log:17485: 2024-09-12T11:57:35+02:00	INFO	pieces	used-space-filewalker completed	{"Process": "storagenode", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Lazy File Walker": true, "Total Pieces Size": 88802578176, "Total Pieces Content Size": 88646027520}
~/Downloads/node (4).log:17486: 2024-09-12T11:57:35+02:00	INFO	pieces	used-space-filewalker started	{"Process": "storagenode", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
~/Downloads/node (4).log:17487: 2024-09-12T11:57:35+02:00	INFO	lazyfilewalker.used-space-filewalker	starting subprocess	{"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
~/Downloads/node (4).log:17488: 2024-09-12T11:57:35+02:00	INFO	lazyfilewalker.used-space-filewalker	subprocess started	{"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
~/Downloads/node (4).log:17490: 2024-09-12T11:57:35+02:00	INFO	lazyfilewalker.used-space-filewalker.subprocess	Database started	{"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Process": "storagenode"}
It should finish each satellite separately. You may search for "\sused-space" and "started|completed" to see a progress.
bash
grep "\sused-space" ~/Downloads/"Node (4).log" | grep -E "started|completed" | tail
PowerShell:
sls "\sused-space" ~/Downloads/"Node (4).log" | sls "started|completed" | select -last 20
If it’s performed always for the same satellite, then probably your node is restarting, you need to search for Unrecoverable and/or FATAL errors to figure out the reason.
bash:
grep error ~/Downloads/"Node (4).log" | grep -E "Unrecoverable|FATAL" | tail
PowerShell:
sls error ~/Downloads/"Node (4).log" | sls "Unrecoverable|FATAL" | select -last 20
